TwinTurbo.NET: Nissan 300ZX forum - I've gotten good results using a speedbleeders bleeder (n/m)
AHos(Chicago)
on April 29, 2012 at 6:54 PM
I've had this bleeders problem too
posted by OverZealous (CT)
on April 29, 2012 at 04:27 PM
Clutch bleed fail
rojoloco (VA Beach)
14:49:09 04/29/12
Maybe the seal on the MC is shot and letting air in?
my91z
15:05:59 04/29/12
No leakage at all.
rojoloco (VA Beach)
15:23:23 04/29/12
One of the bleeders not holding tight and sucking air >>
my91z
15:37:49 04/29/12
OverZealous (CT)
16:27:41 04/29/12
Do you have a write-up? (n/m)
rojoloco (VA Beach)
18:49:21 04/29/12
Not a lot to it - install SB into the slave cylinder,
jzack
22:29:11 04/29/12
Gotcha. I've never used a SB.
rojoloco (VA Beach)
05:29:24 04/30/12
Cheap Siphon Reverse Bleed Setup
OverZealous (CT)
22:16:38 04/30/12
Thanks! I'll have to try this method.
rojoloco (VA Beach)
09:56:09 05/01/12
Did you get my email? (n/m)
my91z
16:16:45 05/01/12
If it was sent today, not yet. I replied to one this morning
rojoloco (VA Beach)
13:43:51 05/02/12
I've gotten good results using a speedbleeders bleeder (n/m) -
AHos(Chicago)
18:54:45 04/29/12
If you can't even shift the car into gear there would
doug8867
21:00:03 05/01/12
I've gotten conflicting info on the clutch booster.
rojoloco (VA Beach)
13:47:00 05/02/12
Agree that booster is not likely to cause your
doug8867
15:13:54 05/02/12
I can try it.
rojoloco (VA Beach)
05:56:39 05/03/12
You had me at:
doug8867
08:20:34 05/03/12
That still leaves a few unanswered questions though.
rojoloco (VA Beach)
11:52:34 05/03/12
Not sure. I had times where I could shift like butter
doug8867
14:40:06 05/03/12
I checked for fluid at the firewall today.
rojoloco (VA Beach)
20:18:49 05/03/12
I would thoroughly clean you slave of wetness, then
doug8867
07:03:45 05/04/12
The slave better not be dead.
rojoloco (VA Beach)
09:11:13 05/04/12
Still trying to picture how a LOT of oil could work itself
doug8867
10:20:23 05/04/12
Now you can fully understand my confusion.
rojoloco (VA Beach)
10:33:13 05/04/12
The pedal adjustment didn't do squat.
rojoloco (VA Beach)
22:18:35 05/04/12
Did you clean your slave first and then inspect
doug8867
09:44:12 05/07/12
Yeah, I cleaned it first.
rojoloco (VA Beach)
08:32:05 05/09/12
Forgot to answer your question about rebuilding MC.
doug8867
11:44:13 05/03/12
